Hi
I added an equipment schedule component to a display and i get the following error message each time it updates
Blockquote
Graphics2D from BufferedImage lacks BUFFERED_IMAGE hint
Blockquote
Any ideas?
Hi
Blockquote
Blockquote
Any ideas?
Hi, That appears to be a Java Swing error message. Are you sure you're using the Perspective and not the Vision Equipment Schedule component?
Okay. You must be talking about from within the Designer. We have a ticket for this already, so it's not just you.
@ynejati
It is perspective, not vision
and yes, it is within designer.
just wondering if this is solved?
what was to root cause?
I am having a similar issue when loading SVG icon in designer not with perspective designer but with my custom module. I think there is something with the loading of SVG icon maybe?
Edit:
Wait this actually still throws the warning when in perspective EquipmentSchedule component
Hello, I'm having a similar issue in perspective (8.1) with an EquipmentSchedule component. Every time I click on either this component or in the perspective components tab also into Equipment Schedule, I get the Graphics2D from BufferedImage lacks BUFFERED_IMAGE hint. Anyone found a root cause or fix?
