Is there a preexisting equivalent of Vision - Multi-State Indicator | Ignition User Manual in perspective? I know there's Perspective - Multi-State Button | Ignition User Manual, but the semantics are slightly different (it displays all 3 states and just has one selected). I can always write my own set of color/text bindings but ideally i'd use something inbuilt.
We all build our own reusable views for this, much more efficient than using the inbuilt one.
Normally you have a way you program indicators that is common across an entire PLC, so we build the indicator to use this structure and then just reuse this component across the project. This saves all the configuration, you just change the tag passed in the parameter, and the view is fully set up.
