Is there an equivalent of the “this” keyword for component properties within the ignition designer? For example, I added Mouseover Text to a bunch of components which was bound to an existing dynamic property on the components:
"<html>" +
{Root Container.Pipe Segment 18.TagNameA} + "<br/>" +
{Root Container.Pipe Segment 18.TagNameB} + "</html>"
For each component I added this to, I had to manually modify the “Pipe Segment 18” portion to correspond to the component that I currently had selected. This makes things a bit more error prone if I happen to typo, plus it makes things a bit more tedious.
Is there a way to do something like below?
"<html>" +
{this.TagNameA} + "<br/>" +
{this.TagNameB} + "</html>"
This would be pretty helpful, especially if it was able to be used if multiple components were selected for retroactively adding stuff to existing components.
