Hello,
If you plan to draw single line diagram or P&ID for a plant floor, you have to use xy coordinate container with percent mode to scale the view for different resolution. For example HD, FHD, UHD, 4K.
I don’t need response design here, and object has complex position relationship so it’s no benefit to use flex,… container here.
The problem is here the percent mode scale and move component base on top left corner not the center of object so it cause everything shift in different resolution and offset with each others.
Is there any workaround for this problem?
Or IA has any plan to add other contanier for this kind of drawing? Some thing that act like vision scaling mode for windows.
