I’m running a project on 8.1.1. I have a few query tags that are configured for a fixed rate. These tags are not updating period unless I manually restart the tag or trigger an update by editing the tag itself. I’ve tried a few combinations of setting the execution mode to Fixed Rate with varying rates between 3000-60000ms. I’ve also tried setting the execution mode to Tag Group on a group that’s set to driven and set to rate between 30-60 seconds. If I manually restart the tag the query executes without error within 50ms or so. Any thoughts?
Download a gateway thread dump next time you notice this and upload it here.
https://docs.inductiveautomation.com/display/DOC81/Diagnostics+-+Threads
Here’s a thread dump
thread_dump20211210-210646.txt (168.5 KB)
Did this issue get resolved?? I am having the same issue.
