org.apache.commons.dbcp.SQLNestedException: Cannot get a connection, pool exhausted
at org.apache.commons.dbcp.PoolingDataSource.getConnection(PoolingDataSource.java:103)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:540)
at com.inductiveautomation.factorypmi.gateway.db.DatasourceManager$DSInfo.createConnection(DatasourceManager.java:575)
at com.inductiveautomation.factorypmi.gateway.db.DatasourceManager.getConnection(DatasourceManager.java:178)
at com.inductiveautomation.factorypmi.gateway.db.DatasourceManager.getConnection(DatasourceManager.java:170)
at com.inductiveautomation.factorypmi.gateway.servlets.Gateway.doDBAction(Gateway.java:2277)
at com.inductiveautomation.factorypmi.gateway.servlets.Gateway.runQuery(Gateway.java:1852)
at com.inductiveautomation.factorypmi.gateway.servlets.Gateway.doPost(Gateway.java:332)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at com.inductiveautomation.factorypmi.gateway.ErrorReportValve.invoke(ErrorReportValve.java:95)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Unknown Source)
Caused by: java.util.NoSuchElementException: Timeout waiting for idle object
at org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:958)
at org.apache.commons.dbcp.PoolingDataSource.getConnection(PoolingDataSource.java:95)
... 23 more
... 23 more
Sorry for the double post. I thought I was editing the first post.
Reason for edit: pasted the correct error message. (expect for the date it does look the same)
This error simply means that the connection pool is full (all connections in use), and no connection became available within the timeout. (the size of the pool and the time to wait are parameters of the connection.
By default the pool has a max of 8 connections. This is sufficient for most applications. The presence of this error typically means one of two things:
You’re running a bunch of queries that are taking a long time to complete, thus they’re filling up the pool. This is usually caused by poorly optimized table layout (lack of indexes)
You’re just running too many queries in general. This is often caused by mistakenly not using the “swap” navigation technique, resulting in many windows being open in the background simultaneously on the clients.
To troubleshoot this, you can turn on the verbose output of the datasource status by appending “&verbose=1” to the end of the url, so the url would be something like this: myhost:8080/gateway/Gateway?tab= … &verbose=1
That will tell you how many connections are currently in use. Because this is a fairly common problem, the next major version has much better troubleshooting tools for this, allowing you to see more detail about the current state of the connection pool.
