After power failure - when the PC turns ON and performs the autologin this error always pops up.
Any possible solutions for removing this error permanently?
Thanks.
You'll have to share your setup to be sure, but that looks like an auto-login auto-client-launch that is running faster than the gateway service startup on the same machine. You just need to wait for the gateway service to start. You can probably adjust the number of retries and the time between retries to make sure it succeeds eventually.
Thanks.
