I install a Bekhoff OPC server to collect the data form there PLC. I could browse the server to get the tag a couple of time but most of the time I got an “Error OPC Browsing”.
The version of Ignition install on the server is 7.6.4. The issue may be due to the fact that the server run on xp with a old version of JAVA and Internet Explorer.
Here is the log file that I got.
Message: Error browsing OPC.
Time: Tue Dec 10 6:50:06AM
Severity: ERROR
Logger: com.inductiveautomation.ignition.designer.sqltags.opcbrowser.AbstractOPCTreeNode
Stack Trace: com.inductiveautomation.ignition.client.gateway_interface.GatewayException:
Results for asynchronous rpc call were not received within the specified amount of time [120000 ms] for task ‘16441596-2e32-4fbe-8532-bdb03975edc7’
at
com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
at
com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at
com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invokeWithTimeout(GatewayInterface.java:807)
at
com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.browseOPC(GatewayInterface.java:811)
at
com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCFolderNode.loadChildren(OPCFolderNode.java:52)
at
com.inductiveautomation.ignition.client.util.gui.tree.AbstractAsynchronousTreeNode$Loader.run(AbstractAsynchronousTreeNode.java:75)
at
java.util.concurrent.Executors$RunnableAdapter.call(Unknown
Source)
at
java.util.concurrent.FutureTask$Sync.innerRun(Unknown
Source)
at
java.util.concurrent.FutureTask.run(Unknown
Source)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown
Source)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown
Source)
at
java.lang.Thread.run(Unknown Source)
Caused by:
java.util.concurrent.TimeoutException: Results for asynchronous rpc call were not received within the specified amount of time [120000 ms] for task ‘16441596-2e32-4fbe-8532-bdb03975edc7’
at
com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$RunningTask.waitForResult(ClientProgressManager.java:486)
at
com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
10 more
Stack Trace: com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source) java.util.concurrent.FutureTask.run(Unknown Source) java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source) java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) java.lang.Thread.run(Unknown Source)
Regards,
