Sorry about that! You should be able to resolve the module-signer dependency if you add the releases repo (as you attempted), as well as the snapshot repo: https://nexus.inductiveautomation.com/repository/inductiveautomation-snapshots.
Alternatively, it should work if you clone https://github.com/inductiveautomation/module-signer and execute mvn install in its root directory (if you have maven installed on your machine), as that is the dependency that it’s failing to resolve.
Feel free to submit a pull request if this fixes the issue and you’re looking to get some github activity points. Otherwise, we’ll get the changes in there soon. I believe we have some more updates planned for the perspective component in the near future due to API changes pending in 8.0.1, so keep an eye out for that over the next week or two as well.
I am seeing a different error as shown in attached text.buildError.txt (2.9 KB)
Am I using correct dependencies ? This is the content from designer build.gradle file -
