Error capture on user.sendRequest
I’m not having luck capturing the error on a system.util.sendRequest call.
On the “GoodServer” the handler exists and functions properly. On the “BadServer” the function fails and reports a “Remote Exception”. The I’m just trying to capture this exception and move on in the script but it does not appear to work in a try block… Something I’m missing?
tagPath = '[MQTT Engine]Edge Nodes/Some/Tag/Path'
server = 'GoodServer'
server = 'BadServer'
try :
	result = system.util.sendRequest('Edge', 'checkPathAlarms', payload = { 'tagPath' : tagPath }, remoteServer = server, timeoutSec = 5 )
except Exception as e :
	pass
	print "Error sending request to %s: %s" %(server,e)
	result = None
if result > 0 :
	print "Checking %d tags with alerms"%result
else :
	print "nothing to process"
Error: (The handler isn’t there and I know it isn’t there, I’m just trying to not tank the script when it happens)
Java Traceback:
  File "<input>", line 6, in <module>
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:330)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)
	at com.inductiveautomation.ignition.client.script.DesignerSystemUtilities$SendRequestManager.invokeRequest(DesignerSystemUtilities.java:388)
	at com.inductiveautomation.ignition.client.script.DesignerSystemUtilities.sendRequestInternal(DesignerSystemUtilities.java:217)
	at com.inductiveautomation.ignition.common.script.builtin.SystemUtilities.sendRequestInternal(SystemUtilities.java:912)
	at com.inductiveautomation.ignition.common.script.builtin.SystemUtilities.sendRequest(SystemUtilities.java:833)
	at jdk.internal.reflect.GeneratedMethodAccessor151.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Remote exception: com.inductiveautomation.ignition.common.script.message.MessageHandlerException: The message handler "checkPathAlarms" could not be found! Check your event script message handlers.
	at org.python.core.Py.JavaError(Py.java:545)
	at org.python.core.Py.JavaError(Py.java:536)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
	at org.python.core.PyObject.__call__(PyObject.java:400)
	at org.python.pycode._pyx438.f$0(<input>:17)
	at org.python.pycode._pyx438.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1703)
	at org.python.core.Py.exec(Py.java:1747)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Remote exception: com.inductiveautomation.ignition.common.script.message.MessageHandlerException: The message handler "checkPathAlarms" could not be found! Check your event script message handlers.
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	... 18 more
Caused by: java.lang.Exception
com.inductiveautomation.ignition.common.GenericTransferrableException: Remote exception: com.inductiveautomation.ignition.common.script.message.MessageHandlerException: The message handler "checkPathAlarms" could not be found! Check your event script message handlers.
	at com.inductiveautomation.ignition.gateway.clientcomm.scriptmsg.AbstractScriptRequestIntent.processInternal(AbstractScriptRequestIntent.java:41)
	at com.inductiveautomation.ignition.gateway.clientcomm.scriptmsg.ScriptRequestIntent.receive(ScriptRequestIntent.java:29)
	at com.inductiveautomation.ignition.gateway.clientcomm.scriptmsg.ScriptRequestIntent.receive(ScriptRequestIntent.java:12)
	at com.inductiveautomation.metro.impl.CentralManagerImpl.handleLocal(CentralManagerImpl.java:483)
	at com.inductiveautomation.metro.impl.ConnectionWatcher.handle(ConnectionWatcher.java:502)
	at com.inductiveautomation.metro.impl.ConnectionWatcher.handle(ConnectionWatcher.java:49)
	at com.inductiveautomation.metro.impl.protocol.websocket.WebSocketConnection.forward(WebSocketConnection.java:1446)
	at com.inductiveautomation.metro.impl.protocol.websocket.WebSocketConnection.onDataReceived(WebSocketConnection.java:1339)
	at com.inductiveautomation.metro.impl.protocol.websocket.servlet.DataChannelServlet.doPost(DataChannelServlet.java:268)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
	at com.inductiveautomation.metro.impl.protocol.websocket.servlet.DataChannelServlet.service(DataChannelServlet.java:195)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
	at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
	at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:598)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1580)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1553)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
	at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
	at org.eclipse.jetty.server.Server.handle(Server.java:563)
	at org.eclipse.jetty.server.HttpChannel$RequestDispatchable.dispatch(HttpChannel.java:1598)
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:753)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:501)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:287)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:558)
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:379)
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:146)
	at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:421)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:390)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:277)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:199)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
Thats a java error, you need to catch those separately from python errors
add
except java.lang.Throwable as e:
	# handle error here
to your try ... except block.
Thank you, sir! You are a gentleman and a scholar!
