Error cloning object through serialization. system.device.addDevice and Gateway Webpage
I routinely get this error when trying to add devices from scripting or gateway webpage. I am wondering why?
java.io.InvalidClassException: com.inductiveautomation.xopc.drivers.logix.LogixDriverSettings; local class incompatible: stream classdesc serialVersionUID = -2480098986308417940, local class serialVersionUID = 7858141426697595421
at java.base/java.io.ObjectStreamClass.initNonProxy(Unknown Source)
at java.base/java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.base/java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.base/java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject0(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject(Unknown Source)
at java.base/java.util.ArrayList.readObject(Unknown Source)
at java.base/jdk.internal.reflect.GeneratedMethodAccessor15.invoke(Unknown Source)
at java.base/java.io.ObjectStreamClass.invokeReadObject(Unknown Source)
at java.base/java.io.ObjectInputStream.readSerialData(Unknown Source)
at java.base/java.io.ObjectInputStream.defaultReadFields(Unknown Source)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RedundantSession.cloneDataset(RedundantPersistenceInterfaceImpl.java:251)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RedundantSession.doCommit(RedundantPersistenceInterfaceImpl.java:271)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RedundantSession.commitAndDetachDataSet(RedundantPersistenceInterfaceImpl.java:263)
at com.inductiveautomation.ignition.gateway.web.components.AbstractRecordEditPanel.commitRecords(AbstractRecordEditPanel.java:206)
at com.inductiveautomation.ignition.gateway.web.components.AbstractRecordEditPanel.onSubmit(AbstractRecordEditPanel.java:158)
at com.inductiveautomation.ignition.gateway.web.components.AbstractRecordEditPanel.onSubmit(AbstractRecordEditPanel.java:125)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm$1.onSubmitInternal(RecordEditForm.java:94)
at com.inductiveautomation.ignition.gateway.web.components.CsrfPreventingForm.onSubmit(CsrfPreventingForm.java:67)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1310)
at org.apache.wicket.markup.html.form.Form.process(Form.java:967)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:789)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:701)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:243)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:236)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:890)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:261)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:218)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:289)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:259)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:201)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:282)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
Please contact support with the exact steps/scripts you’re using (and what version you’re on).
