Hello,
We have created tags using scripting function.
However, when we try to export tags to json, we are getting below error. We are not able to identify the issue. Could you please review and let me know what is wrong?
java.io.IOException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.RuntimeException: Error cloning object through serialization.
- at com.inductiveautomation.ignition.designer.tags.frame.actions.TagExporterTask.writeToFile(ImportExportActions.kt:570)*
- at com.inductiveautomation.ignition.client.script.ClientFileUtilities$CharFileWritingTask.writeToFile(ClientFileUtilities.java:84)*
- at com.inductiveautomation.ignition.designer.util.FileUtil.saveToFile(FileUtil.java:110)*
- at com.inductiveautomation.ignition.designer.tags.frame.actions.ExportAction.actionPerformed(ImportExportActions.kt:340)*
- at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)*
- at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)*
- at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)*
- at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)*
- at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)*
- at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)*
- at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)*
- at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)*
- at java.desktop/java.awt.Component.processMouseEvent(Unknown Source)*
- at java.desktop/javax.swing.JComponent.processMouseEvent(Unknown Source)*
- at java.desktop/java.awt.Component.processEvent(Unknown Source)*
- at java.desktop/java.awt.Container.processEvent(Unknown Source)*
- at java.desktop/java.awt.Component.dispatchEventImpl(Unknown Source)*
- at java.desktop/java.awt.Container.dispatchEventImpl(Unknown Source)*
- at java.desktop/java.awt.Component.dispatchEvent(Unknown Source)*
- at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)*
- at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)*
- at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)*
- at java.desktop/java.awt.Window.dispatchEventImpl(Unknown Source)*
- at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)*
- at java.desktop/java.awt.EventQueue$4.run(Unknown Source)*
- at java.base/java.security.AccessController.doPrivileged(Native Method)*
- at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)*
- at java.desktop/java.awt.EventQueue$5.run(Unknown Source)*
- at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)*
- at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)*
- at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)*
- at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)*
- at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)*
- at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)*
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.RuntimeException: Error cloning object through serialization. - at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)*
- at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)*
- at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)*
- at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:954)*
- at com.inductiveautomation.ignition.designer.tags.frame.actions.ExportTaskFactory.createWritingTask$lambda-2(ImportExportActions.kt:532)*
- at com.inductiveautomation.ignition.designer.tags.frame.actions.TagExporterTask.writeToFile(ImportExportActions.kt:568)*
- ... 41 more*
Caused by: java.util.concurrent.ExecutionException: java.lang.RuntimeException: Error cloning object through serialization. - at java.util.concurrent.CompletableFuture.reportGet(null)*
- at java.util.concurrent.CompletableFuture.get(null)*
- at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.TagProviderRpc.getTagExport(TagProviderRpc.java:734)*
- at jdk.internal.reflect.GeneratedMethodAccessor70.invoke(null)*
- at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)*
- at java.lang.reflect.Method.invoke(null)*
- at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:228)*
- at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:431)*
- at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)*
- at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)*
- at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)*
- at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1450)*
- at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)*
- at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1631)*
- at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)*
- at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)*
- at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)*
- at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)*
- at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)*
- at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)*
- at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)*
- at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)*
- at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)*
- at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)*
- at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)*
- at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)*
- at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)*
- at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)*
- at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)*
- at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)*
- at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)*
- at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)*
- at org.eclipse.jetty.server.Server.handle(Server.java:516)*
- at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)*
- at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)*
- at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)*
- at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)*
- at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)*
- at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)*
- at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)*
- at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)*
- at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)*
- at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)*
- at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)*
- at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)*
- at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)*
- at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)*
- at java.lang.Thread.run(null)*
Ignition v8.1.22 (b2022110109)
Java: Azul Systems, Inc. 11.0.16.1
