Error column reference " " is ambiguous
Hi all,
I’m using the script below on a property change event of a PLC tag and I get the error column reference “serialnumber” is ambiguous.
Anybody know what that means?
Thanks!
 	if currentValue.value == True:
		laserdata = system.tag.read("[.]LaserSinkNumber").value
		db = 'PostgreSQL'
		if system.tag.read("[.]LaserFail").value == True:
			laser = 'Scan Failed'
			query = """
			INSERT INTO packtrack (generictime, lasertime, lasersink)
			VALUES (CURRENT_TIMESTAMP, CURRENT_TIMESTAMP, ?)
			system.db.runPrepUpdate(query, [laser], db)
		else:
			laser = 'Scan Successful'
			query = """
			INSERT INTO packtrack (serialnumber, generictime, lasertime, lasersink)
			VALUES (?, CURRENT_TIMESTAMP, CURRENT_TIMESTAMP, ?)
			ON CONFLICT (serialnumber) DO UPDATE
			SET generictime = EXCLUDED.generictime, lasertime = EXCLUDED.lasertime, lasersink = EXCLUDED.lasersink
			WHERE serialnumber=?
			system.db.runPrepUpdate(query, [laserdata, laser, laserdata], db)
It means that there is more than one column named serialnumber and SQL doesn’t know which one to use. If I had to guess, you probably need to change serialnumber to either packtrack.serialnumber or EXCLUDED.serialnumber in your WHERE clause.
I changed my script as below and now I get this:
ERROR: there is no unique or exclusion constraint matching the ON CONFLICT specification
Does the column ON CONFLICT is looking at have to be a integer? Right now my serialnumber column is a string.
		print "line 4"
		laserdata = system.tag.read("[.]Laser_Sink_Number").value
		db = 'PostgreSQL'
		if system.tag.read("[.]Laser_Barcode_Error").value == True:
			query = """
			print "line 14"
		else:
			query = """
			SET generictime = CURRENT_TIMESTAMP, lasertime = CURRENT_TIMESTAMP, lasersink = ?
			WHERE packtrack.serialnumber=?
			system.db.runPrepUpdate(query, [laserdata, laser, laser, laserdata], db)
			print "end"
To trigger a conflict clause, your table needs to be set up so that serialnumber (in this case) is marked as unique/exclusive, in Postgres. You need to update your table configuration.
I figured it out.
For the ON CONFLICT to work you have to create a unique index on the column you’re looking at
