The snapshot got removed?
In the git example its still configured as this one, where do i find the correct version?
Could not resolve all artifacts for configuration ':classpath'.
> Could not resolve com.inductiveautomation.gradle:ignition-module-plugin:1.2.10-SNAPSHOT.
Required by:
project :
> Could not get resource 'https://plugins.gradle.org/m2/com/inductiveautomation/gradle/ignition-module-plugin/1.2.10-SNAPSHOT/ignition-module-plugin-1.2.10-SNAPSHOT.pom'.
> Could not GET 'https://repo.gradle.org/artifactory/jcenter/com/inductiveautomation/gradle/ignition-module-plugin/1.2.10-SNAPSHOT/ignition-module-plugin-1.2.10-SNAPSHOT.pom'. Received status code 409 from server: Conflict
> Unable to load Maven meta-data from https://jcenter.bintray.com/com/inductiveautomation/gradle/ignition-module-plugin/1.2.10-SNAPSHOT/maven-metadata.xml.
> Could not get resource 'https://jcenter.bintray.com/com/inductiveautomation/gradle/ignition-module-plugin/1.2.10-SNAPSHOT/maven-metadata.xml'.
> Could not GET 'https://jcenter.bintray.com/com/inductiveautomation/gradle/ignition-module-plugin/1.2.10-SNAPSHOT/maven-metadata.xml'.
> Read timed out
