Installed a trial of Kepware Server EX 6.4 and am trying to connect to it from my Ignition server. I followed the directions at https://docs.inductiveautomation.com/display/DOC/Connecting+to+Kepware+OPC-UA but am getting an “faulted” status and error of “no acceptable UserTokenPolicy present on selected endpoint”. I have tried switching between the IP address and localhost when making the connection but that doesn’t seem to help. I did trust the client from within the Kepware server as stated in the instructions. Any ideas?
“no acceptable UserTokenPolicy present on selected endpoint” means either:
- you’re trying to connect without a username and password configured but Kepware requires one.
- you’re trying to connect with a username and password but Kepware does not want one.
Hmm - interesting. When I created the connection in Ignition I left the username/password fields blank as instructed, and didn’t specifically set a username/password on the Kepware side when installing it?
I don’t think Kepware allows anonymous connections by default. Check the UA configuration area.
