Hello, I am trying to establish an OPC-UA connection to Kepware from Ignition. When trying to connect in Ignition, I keep getting the following error:
UaException: status=Bad_SecurityChecksFailed, message=An error occurred verifying security.
at org.eclipse.milo.opcua.stack.client.handlers.UaTcpClientAcknowledgeHandler.onError(UaTcpClientAcknowledgeHandler.java:232)
at org.eclipse.milo.opcua.stack.client.handlers.UaTcpClientAcknowledgeHandler.decode(UaTcpClientAcknowledgeHandler.java:128)
at io.netty.handler.codec.ByteToMessageCodec$1.decode(ByteToMessageCodec.java:42)
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:387)
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:245)
at io.netty.handler.codec.ByteToMessageCodec.channelRead(ByteToMessageCodec.java:103)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:292)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:278)
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:962)
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:528)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:485)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:399)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:371)
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112)
at java.lang.Thread.run(Unknown Source)
Someone on a somewhat similar post suggested that doing an edit/save would work but it hasn’t for me. I’m not really sure what to do and I would really appreciate some help! Thanks in advance!
