Error: Could not open jvm.cfg file
This error appears after that the VM was rebooted because the jvm.cfg was not there. Do you know why the file can be deleted.
Failed to parse the version of Java. Resolving to the lowest supported version (1.4).
ADVICE | wrapper | 2024/09/22 03:15:24 | Please set wrapper.java.version.output to TRUE, relaunch the Wrapper to print out the Java version output, and send the log file to support@tanukisoftware.com.
STATUS | wrapper | 2024/09/22 03:15:24 | Launching a JVM...
INFO | jvm 1 | 2024/09/22 03:15:26 | Error: could not open `D:\Program Files\Inductive Automation\Ignition\lib\runtime\jre-win\lib\jvm.cfg'
