I’m getting the following error in the client console whenever the client receives an update to the fpmi/client_tags resource. That is, whenever anyone holding an edit lock on fpmi/client_tags presses save in the designer.
ERROR [ProjectTag-ProjectUpdater] Error creating tag binding.
java.lang.RuntimeException: Type mismatch in operation 'DIVIDE': expected 'Number', found 'String'
at com.inductiveautomation.ignition.common.expressions.AbstractExpression.typeMismatch(AbstractExpression.java:20)
at com.inductiveautomation.ignition.common.expressions.ArithmeticExpression.<init>(ArithmeticExpression.java:33)
at com.inductiveautomation.ignition.common.expressions.parsing.CUP$ELParser$actions.CUP$ELParser$do_action(ELParser.java:936)
at com.inductiveautomation.ignition.common.expressions.parsing.ELParser.do_action(ELParser.java:323)
at java_cup.runtime.lr_parser.parse(lr_parser.java:569)
at com.inductiveautomation.ignition.common.expressions.parsing.ELParserHarness.parse(ELParserHarness.java:22)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTag.createTagBinding(ProjectTag.java:83)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTag.startBindingImpl(ProjectTag.java:117)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTag.startBinding(ProjectTag.java:107)
at com.inductiveautomation.factorypmi.application.sqltags.ClientTagFolder.startBinding(ClientTagFolder.java:152)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTagManager.setRoot(ProjectTagManager.java:407)
at com.inductiveautomation.factorypmi.application.FPMIApp.applyDiff(FPMIApp.java:546)
at com.inductiveautomation.factorypmi.application.runtime.UpdateProjectPane$ApplyDiff.run(UpdateProjectPane.java:123)
at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:32)
at java.lang.Thread.run(Thread.java:662)
It’s almost certainly a problem with one of my tags. However, the error message does not tell me which tag is causing the problem. Please can this be fixed?
Thanks.
