Error During Tag Export
Hi there, when trying to import tags into ignition I am getting the following error from Ignition!
Any ideas?
jeremy was here 0-70 .json (27.0 KB)
Look at the JSON file you have in a text editor. It's completely broken.
Line 194 that it's complaining about is the literal text #VALUE! with no JSON syntax surrounding it, but even removing that, there's weird gaps of empty lines, and the whole file is not well-formed JSON otherwise.
After opening the file in Kate and running the JSON formatter on it. I was able the import the results. It's up to you to see if everything is there or not.
YMMV.
formattedTags.json (47.3 KB)
