Error executing function Alarmin.acknowlege in client
I have an error in the barner or alarm table, to be exact in the client and is “error executing function, ‘Alarming.acknowledge’. the current user does not have the required roles for this operation”, it happens that I can not perform the Acknowlege and I get that error, please support me with this case,
Client permissions are changed by default on a new install of Ignition 7.9.4+; you can either change these permissions or build them into your security.
https://docs.inductiveautomation.com/display/DOC79/Project+Properties#ProjectProperties-ClientPermissions
Thanks for your help, the error was solved
