Error executing redundant state sync. Provider=tagstore-System
Hi I have the following appearing in the logs over and over really fast.
Did you change your setup while your backup server was disconnected? Module updates? Other version updates?
(What Ignition version is this?)
Its running 8.1.13
I haven’t done anything new after upgrading the server a while ago. I tried to hunt down on forums someone with the same issue with no luck.
You need to contact support (support.inductiveautomation.com). This is a bug in Ignition, and they can help you with next steps to take.
I ended up forcing the backup to resync and the errors stopped.
I will contact them if it happens again.
Hello, We are trying to add redundancy to our main gateway running Version 8.1.20 and are receiving similar errors as below. Is this also part of the bug that you had mentioned in this thread previously? Any help will be much appreciated..
No, the inner error there is a socket timeout, indicating some networking problem outside of Ignition between the two gateways.
