Error executing redundant state sync
Hello,
I am running version 8.1.48 on a redundant pair of ignition servers, and I have been getting the following error on the Master's Logs
System Event:
[tagprovider-Tier1] Will perform full pull. Reason: redundant provider on local side has no data.
Log Activity
SyncManager	18Jun2025 12:10:00	Error executing redundant state sync. Provider=tagprovider-Tier1
and when I expand this log activity, I get the following:
java.lang.ClassCastException: cannot assign instance of java.util.HashMap to field com.inductiveautomation.ignition.gateway.redundancy.types.State.result of type com.inductiveautomation.ignition.common.model.values.QualityCode in instance of com.inductiveautomation.ignition.gateway.redundancy.types.State
at java.base/java.io.ObjectStreamClass$FieldReflector.setObjFieldValues(Unknown Source)
at java.base/java.io.ObjectStreamClass$FieldReflector.checkObjectFieldValueTypes(Unknown Source)
at java.base/java.io.ObjectStreamClass.checkObjFieldValueTypes(Unknown Source)
at java.base/java.io.ObjectInputStream$FieldValues.defaultCheckFieldValues(Unknown Source)
at java.base/java.io.ObjectInputStream.readSerialData(Unknown Source)
at java.base/java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject0(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject(Unknown Source)
at com.inductiveautomation.metro.impl.codecs.JavaSerializationCodec.decode(JavaSerializationCodec.java:65)
at com.inductiveautomation.metro.impl.codecs.ServiceResponseCodec.decode(ServiceResponseCodec.java:70)
at com.inductiveautomation.metro.impl.CentralManagerImpl.handleLocal(CentralManagerImpl.java:444)
at com.inductiveautomation.metro.impl.ConnectionWatcher.handle(ConnectionWatcher.java:502)
at com.inductiveautomation.metro.impl.ConnectionWatcher.handle(ConnectionWatcher.java:49)
at com.inductiveautomation.metro.impl.protocol.websocket.WebSocketConnection.forward(WebSocketConnection.java:1446)
at com.inductiveautomation.metro.impl.protocol.websocket.WebSocketConnection.onDataReceived(WebSocketConnection.java:1339)
at com.inductiveautomation.metro.impl.protocol.websocket.servlet.DataChannelServlet.doPost(DataChannelServlet.java:268)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
at com.inductiveautomation.metro.impl.protocol.websocket.servlet.DataChannelServlet.service(DataChannelServlet.java:195)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:558)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:379)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:146)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
I was wondering if anyone has seen this before, or can point me in a direction. I have tried the following:
  1. Verified both master and backup are online and connected to eachother
  2. Restarting Ignition Service on Master and Backup
  3. Restarting both servers
  4. upgrading to the latest version of ignition (I was on version 8.1.47)
Thank you!
Looks like a bug. You should open a support ticket.
Sure. I can do that.
I do have 2 other pairs of ignition running the same version without any errors. So I was thinking it is more likely a config error somewhere.
