Error executing script. Traceback (most recent call last): File "<tagevent:valueChanged>", line 19, in valueChanged
Hello everybody,
I am getting some issues writing data into a MySQL database, I am running my query into a Tag Event Script, some times the script run well but another it doesn’t and the issue log is the following
“Error executing script.
File “tagevent:valueChanged”, line 19, in valueChanged
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258)
at jdk.internal.reflect.GeneratedMethodAccessor83.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate”
My script is the following
Does anybody knows why I am getting this error?
Can you post the full stack trace of the error?
This is the full log of the error
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 19, in valueChanged at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258) at jdk.internal.reflect.GeneratedMethodAccessor83.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO tblTiempos (NoTurno, NoModelo, NoBascula, TiempoTare, TiempoClamp, TiempoLlenado, Usuario, Fecha, TiempoCyD) VALUES (?,?,?,?,?,?,?,?,?), [1, 1, 1, Wed Dec 16 16:27:51 PST 2020, Wed Dec 16 16:41:39 PST 2020, 158, JMendoza, Wed Dec 16 16:41:39 PST 2020, 9], SQLUsrTiemposConnection, , false, false)
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:524)
at org.python.core.PyObject.__call__(PyObject.java:515)
at org.python.core.PyObject.__call__(PyObject.java:519)
at org.python.pycode._pyx229.valueChanged$1(:19)
at org.python.pycode._pyx229.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyFunction.function___call__(PyFunction.java:471)
at org.python.core.PyFunction.__call__(PyFunction.java:466)
at org.python.core.PyFunction.__call__(PyFunction.java:461)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:822)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:806)
at com.inductiveautomation.ignition.gateway.tags.scripting.TagScriptManagerImpl$FunctionInvokerImpl.run(TagScriptManagerImpl.java:527)
at com.inductiveautomation.ignition.gateway.tags.scripting.events.AbstractTagScript.invoke(AbstractTagScript.java:34)
at com.inductiveautomation.ignition.gateway.tags.scripting.TagScriptManagerImpl$Task.invoke(TagScriptManagerImpl.java:476)
at com.inductiveautomation.ignition.gateway.tags.scripting.TagScriptManagerImpl$TagScriptDispatcher.run(TagScriptManagerImpl.java:439)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
Caused by: org.python.core.PyException: Traceback (most recent call last): File "", line 19, in valueChanged at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258) at jdk.internal.reflect.GeneratedMethodAccessor83.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO tblTiempos (NoTurno, NoModelo, NoBascula, TiempoTare, TiempoClamp, TiempoLlenado, Usuario, Fecha, TiempoCyD) VALUES (?,?,?,?,?,?,?,?,?), [1, 1, 1, Wed Dec 16 16:27:51 PST 2020, Wed Dec 16 16:41:39 PST 2020, 158, JMendoza, Wed Dec 16 16:41:39 PST 2020, 9], SQLUsrTiemposConnection, , false, false)
... 30 common frames omitted
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO tblTiempos (NoTurno, NoModelo, NoBascula, TiempoTare, TiempoClamp, TiempoLlenado, Usuario, Fecha, TiempoCyD) VALUES (?,?,?,?,?,?,?,?,?), [1, 1, 1, Wed Dec 16 16:27:51 PST 2020, Wed Dec 16 16:41:39 PST 2020, 158, JMendoza, Wed Dec 16 16:41:39 PST 2020, 9], SQLUsrTiemposConnection, , false, false)
... 29 common frames omitted
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Violation of PRIMARY KEY constraint 'PK_tblTiempos'. Cannot insert duplicate key in object 'dbo.tblTiempos'. The duplicate key value is (1, 1, 1, Dec 16 2020 4:27PM).
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:256)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1621)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:592)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:522)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7194)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2930)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:248)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:223)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:471)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:1016)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepUpdate(SRConnectionWrapper.java:183)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities._runPrepStmt(GatewayDBUtilities.java:186)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:256)
... 27 common frames omitted
type or paste code here
This is the key part of the error and why that particular script invocation didn’t work (violation of a primary key constraint):
I solved the problem creating an extra key column into my DB with a number ID that is changing in each row, now my script is working well all times and storages the info correctly.
Thanks!
