Error executing system.db.execSProcCall()
import datetime
def AF_StepPower(Heat_No):
call = system.db.createSProcCall(“sp_calcstepwisepower”)
call.registerInParam(“ps_heatnumber”, system.db.VARCHAR, Heat_No)
system.db.execSProcCall(call)
I have this script in my ignition. I want to call store procedure with one string type of parameter. Store procedure is in MySql and Ignition version is 7.9.10
Script is giving following error :at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:496)
at sun.reflect.GeneratedMethodAccessor148.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.execSProcCall()
When I tried the same with console script window its executing properly but on tab event change it is not working .
what should be done in such case ?
have you tried adding the DB? something like
call = system.db.createSProcCall(“sp_calcstepwisepower”,"DB_NAME")
Hi guys.
Im having the same issue. Can you share with me how did you solve it ?
