I have an fpmi table that the users select rows from and export them to Excel. I sometimes get an error, which I think may be because some of the fields are null and I can’t seem to get this to work.
Here is what I have:
table = event.source.parent.getComponent("Table")
rows = table.getSelectedRows()
headers = ["ID","Code","DtFilled","Gen","FermTank","DtReck","pH","CellCt","Trub","Viability"]
data = []
line = []
pdata = fpmi.db.toPyDataSet(table.data)
for row in rows:
for col in range(table.data.columnCount):
line.append(table.data.getValueAt(row,col))
data.append(line)
line = []
exportds = fpmi.db.toDataSet(headers,data)
fpmi.dataset.exportExcel("YeastData",1,exportds)
There are actually 18 columns in the dataset, I just shorted the header listing in the code here.
The error I get varies as to line and column reporting the error depending on what rows I selected.
ERROR - Error executing script for event: mouseClicked
on component: Table. [AWT-EventQueue-0]
Traceback (innermost last):
File “event:mouseClicked”, line 13, in ?
TypeError: Unable to convert row 4, column 5 to type class java.lang.String
at org.python.core.Py.TypeError(Py.java)
at com.inductiveautomation.factorypmi.application.script.builtin.DatasetUtilities.toDataSet(DatasetUtilities.java:177)
at com.inductiveautomation.factorypmi.application.script.builtin.DBUtilities.toDataSet(DBUtilities.java:204)
at sun.reflect.GeneratedMethodAccessor584.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java)
at org.python.core.PyObject.__call__(PyObject.java)
at org.python.core.PyObject.invoke(PyObject.java)
at org.python.pycode._pyx108.f$0(<event:mouseClicked>:13)
at org.python.pycode._pyx108.call_function(<event:mouseClicked>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.factorypmi.application.script.ScriptManager.runCode(ScriptManager.java:245)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:145)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:287)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at $Proxy1.mouseClicked(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.util.EventDelegateDispatcher$MouseEventDispatcher.mouseClicked(EventDelegateDispatcher.java:94)
