Hi
I have problem error fetching resource.
Please explain problem and solution solve.
Thank you.
without more information on the logs there isn't much help you can be provided.
You may try and click the plus to see what the error is, as well as hovering over Routes may give you some additional information.
I would suggest posting that additional information here to allow for more help.
Hello guys I'm also experiencing a similar problem with an error log Routes where the message is Error fetching resource.
Please find the attached code:
org.eclipse.jetty.io.EofException: null
at org.eclipse.jetty.io.SocketChannelEndPoint.flush(SocketChannelEndPoint.java:116)
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422)
at org.eclipse.jetty.io.WriteFlusher.completeWrite(WriteFlusher.java:377)
at org.eclipse.jetty.io.SelectableChannelEndPoint$2.run(SelectableChannelEndPoint.java:67)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:370)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
Caused by: java.io.IOException: An established connection was aborted by the software in your host machine
at java.base/sun.nio.ch.SocketDispatcher.writev0(Native Method)
at java.base/sun.nio.ch.SocketDispatcher.writev(Unknown Source)
at java.base/sun.nio.ch.IOUtil.write(Unknown Source)
at java.base/sun.nio.ch.SocketChannelImpl.write(Unknown Source)
at java.base/java.nio.channels.SocketChannel.write(Unknown Source)
at org.eclipse.jetty.io.SocketChannelEndPoint.flush(SocketChannelEndPoint.java:110)
... 12 common frames omitted
The main part of the error I think is this:
Since this application is being used by around 50 clients, I’m wondering — could this error be triggered whenever a few clients are disconnected? Perhaps it happens every time a connection to one of them drops?
I'm not entirely sure, so I’d appreciate any insights or perspectives from anyone who has encountered a similar issue.
That message fairly commonly indicates a firewall or antivirus application interfering.
