ERROR: Found an unexpected leaf node
I’m getting this error, and had some other logs that look related:
AgentEdgeNode	16Jun2022 16:41:40	Found an unexpected leaf node newMetricPath=Rejeter-B_CNT_PV_DIFF and metric.getName()=Rejeter-B_CNT_PV
AgentEdgeNode	16Jun2022 16:41:40	Found UDT match: 'Rejeter-B_CNT_PV_DIFF' startswith 'Rejeter-B_CNT_PV'
AgentEdgeNode	16Jun2022 16:41:40	Building UDT Data metric - Child metric name: Rejeter-B_CNT_PV
AgentEdgeNode	16Jun2022 16:41:40	Building UDT Data metric - Child metric: Metric [name=Rejeter-B_CNT_PV, alias=null, timestamp=1655389842381, dataType=Int64, isHistorical=false, isTransient=false, metaData=MetaData [isMultiPart=null, contentType=null, size=null, seq=null, fileName=null, fileType=null, md5=null, description=null], properties=PropertySet [propertyMap={Name_EN=PropertyValue [type=String, value=Reject-B_CNT_PV, isNull=false], documentation=PropertyValue [type=String, value=Number of Rejected Objects to the A rejector, isNull=false]}], value=117613, isNull=false]
AgentEdgeNode	16Jun2022 16:41:40	Device metric is null for Device=CLW-STRUCTURED/P04/PELER and metricName=TRIEUR-OPTICQUE/Trieur-Opticque-1/Rejeter-B_CNT_PV_DIFF
I have no idea what it does or what it breaks, but the tag has a pollrate of 1 min, and this error happens every minute. I have looked to the tags that are mentioned, but I’ve got no clue what would be going wrong. Everything seems to work just fine, but I don’t like having my logs with errors every minute.
Do you have any third party modules installed? I don’t see anywhere in our code that would log those messages.
AgentEdgeNode is comming from CirrusLink MQTT Transmission. Should I pick it up with them?
Yes. They’ll engage with us (or tell you to) if it’s ultimately something coming from Ignition.
Did you ever work out what the issue was with CirrusLink? I recently started to get this error as well.
Hi, @mgrishaber, no, we didn’t pick it up yet.
If you’re running MQTT Transmission 4.0.11, there is a bug with how it handles UDTs if you have member names that build off one another like you have with Rejeter-B_CNT_PV and Rejeter-B_CNT_PV_DIFF. This causes the errors and the warnings in the log that you’ve been seeing.
This has been corrected in MQTT Transmission 4.0.12 that was released late last week. I just finished rolling that out yesterday and it does correct the issue from what I can tell.
Ok cool, we will test 4.0.12.
