Dear Carl,
While I am accessing application from client on WAN I m getting this error so many times.
Regards
Shailesh
Dear Carl,
Regards
Shailesh
You’ll find a log message for the exception that caused the disconnect under the Diagnostics panel in the Client. If this is only happening over the WAN, it is probably a timeout. Connections to the Gateway have a default 60 second timeout. If a large query needs more time than that to return, you may need to turn up the timeout. See the fpmi.system.setConnectTimeout function.
