I have a table populated by a query that returns 11762 rows. If I edit a value in the new editable table I get the following error. If I change the query to return the Top 9999 rows, then I don’t get this error and I am able to edit the table cells.
java.lang.UnsupportedOperationException: Optimized datasets don’t support access of data directly.
at com.inductiveautomation.factorypmi.application.gateway.OptimizedDataSet.getData(OptimizedDataSet.java:97)
at com.inductiveautomation.factorypmi.application.components.PMITable$DataSetTableModel.setValueAt(PMITable.java:1812)
at com.inductiveautomation.factorypmi.application.components.table.SortTableModel.setValueAt(SortTableModel.java:306)
at javax.swing.JTable.setValueAt(Unknown Source)
at javax.swing.JTable.editingStopped(Unknown Source)
at javax.swing.AbstractCellEditor.fireEditingStopped(Unknown Source)
at javax.swing.DefaultCellEditor$EditorDelegate.stopCellEditing(Unknown Source)
at javax.swing.DefaultCellEditor.stopCellEditing(Unknown Source)
at javax.swing.JTable$GenericEditor.stopCellEditing(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI$Handler.mousePressed(Unknown Source)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
FactoryPMI v3.3.0 (build 2430)
Java: Sun Microsystems Inc. 1.6.0_10
