Error Illegal type for X value: class java.lang.String (column 'horas')
Hello I have the next query
but return the next error
IllegalArgumentException: Illegal type for X value: class java.lang.String (column ‘horas’)
Ignition v7.9.9 (b2018081621)
Java: Oracle Corporation 1.8.0_251
in the Dataset is correct the information
Can you elaborate a little ? Is it trying to fetch the Info from Database ? If so, to a table ? What are you exactly trying to do ?
yes, this is my query
SELECT CONVERT(VARCHAR, Fecha, 108),
SUM(CASE WHEN Linea = 'Linea_Disco' THEN Qty else 0 END) as 'Linea_Disco',
SUM(CASE WHEN Linea = 'Linea_Rim' THEN Qty else 0 END) as 'Linea_Rim',
SUM(CASE WHEN Linea = 'Linea_Assy' THEN Qty else 0 END) as 'Linea_Assy',
SUM(CASE WHEN Linea = 'Linea_ED' THEN Qty else 0 END) as 'Linea_ED',
SUM(CASE WHEN Linea = 'Linea_TC' THEN Qty else 0 END) as 'Linea_TC'
from HistoricoContador
where CONVERT (date,Fecha) = dateadd(day, -0,CAST(GETDATE() as DATE))
GROUP BY CONVERT(VARCHAR, Fecha, 108)
ORDER BY CONVERT(VARCHAR, Fecha, 108) ASC
Your X-axis (horas) is an invalid type (String, because you converted it to VARCHAR in the query).
ok, so what can I do to group myself by hours
How about this query ?
SELECT CONVERT(Date, Fecha, 108) AS horas,
       SUM(CASE WHEN Linea = 'Linea_Disco' THEN Qty else 0 END) AS 'Linea_Disco',
       SUM(CASE WHEN Linea = 'Linea_Rim' THEN Qty else 0 END) AS 'Linea_Rim',
       SUM(CASE WHEN Linea = 'Linea_Assy' THEN Qty else 0 END) AS 'Linea_Assy',
       SUM(CASE WHEN Linea = 'Linea_ED' THEN Qty else 0 END) AS 'Linea_ED',
       SUM(CASE WHEN Linea = 'Linea_TC' THEN Qty else 0 END) AS 'Linea_TC'
FROM  HistoricoContador
WHERE Fecha >= DATEADD(day, -0, convert(date, GETDATE()))
ORDER BY Fecha
I think I already solved, I used DATEPART
SELECT DATEPART ( hour , Fecha),
GROUP BY DATEPART ( hour , Fecha)
ORDER BY DATEPART ( hour , Fecha) ASC
