Hi.
I connected a Ignition Gateway 8.1 with a Ignition Edge, but I cannot see the tags.
Is there another configuration that I forgot?
Hello,
The first thing I would like for you to check is if your Edge Sync Service plugin or Edge IIoT is licensed and installed. This can be checked in the Config > Overview subsection. These plugins allow Edge gateways to act as remote tag providers. This was a change made not so long ago (sometime late 8.0.x). If you require assistance with licensing I recommend you contact your account rep.
If that isn’t the issue, confirm that the level for tag access across the board is set to ReadWriteEdit.
