I have a problem in communicating to ABB OPC Server. I have followed the DCOM setting procedure but fedup with getting communicating to that OPC Server.
When MetrikonOPC server for simulation is used, class not registered error has been reported. Error msg attached.
Am using Ignition 7.0.10. on Windows 2003 and OPC server on other windows 2003 server.
I recommend reviewing DCOM configurations that will enable your remote connections. Depending on your current operating system, select a document from the list below:
