Hello,
I tried to run a script to copy some files from a directory to a ftp path.
I tried this script in the “Interactive Script Tester” and it works:
import shutil, os, datetime, sys, traceback, binascii
shutil.copy2("D:\\SharedFolderSCADA\\2017\\01\\10\\Buffer - Belt 1 - 2017-01-10_10-34-59.dat","\\\TEST_FOLDER\\SharedFolderEVO\\2017-01-10\\Buffer - Belt 1 - 2017-01-10_10-34-59.dat")
This script copy the file from the folder in SCADA pc to the ftp path correctly.
When I try to put this script in a value changed of one tag, I have this error about the permission:
File "user-lib\pylib\shutil.py", line 96, in copy2
copyfile(src, dst)
File "user-lib\pylib\shutil.py", line 52, in copyfile
fdst = open(dst, 'wb')
IOError: [Errno 13] Permission denied: '\\\\TEST_FOLDER\\SharedFolderEVO\\2017-01-10\\Buffer - Belt 1 - 2017-01-10_10-34-59.dat'
I think is a permission in a value change or something like this, but I don’t know how to solve. The script works in the tester script of the designer, but not works in the value change.
I have to run this script periodically, every 5 minutes.
Could you please help me?
Andrea
