Hi Guys,
I'm trying to excute the script below with variable but I allways get error, is there any one can help me into how pass avariable to the command "system.db.runUpdateQuery"
query_01="INSERT INTO predictive_test_data (station_number, line_number, test_ID, test_result_value, test_date_and_time)"
query_02=" VALUES (?,?,?,?,?)"
row_data= (st_number,'plm_num',test_id ,test_value ,'datetime')
query=query_01 + query_02
print query
system.db.runUpdateQuery(query ,row_data)
Error
Java Traceback:
File "", line 14, in
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:183)
java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery(INSERT INTO predictive_test_data (station_number, line_number, test_ID, test_result_value, test_date_and_time) VALUES (10,'s000001',21 ,1543 ,'2019.08.20 10:10:34'), , , false)
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:514)
at org.python.core.PyObject.__call__(PyObject.java:480)
at org.python.core.PyObject.__call__(PyObject.java:484)
at org.python.pycode._pyx34.f$0(<buffer>:16)
at org.python.pycode._pyx34.call_function(<buffer>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at org.python.core.Py.exec(Py.java:1658)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:131)
at org.python.util.InteractiveInterpreter.runsource(InteractiveInterpreter.java:116)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:506)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:494)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runUpdateQuery(INSERT INTO predictive_test_data (station_number, line_number, test_ID, test_result_value, test_date_and_time) VALUES (10,'s000001',21 ,1543 ,'2019.08.20 10:10:34'), , , false)
... 27 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run this function when in read-only mode.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:374)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:273)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runUpdateQuery(ClientDBUtilities.java:189)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:181)
... 25 more
