Using Perspective I keep seeing this error over and over again in the gateway logs.
Received updates for missing view instance Blast/Blast@C
@craigb Are you still seeing this issue? If so, can you provide us with more details?
What version are you using?
I still still see this error now and then, I’m on the latest nightly.
It doesn’t appear to create any problems so was just wondering what could cause it so I can fix the error, if it indeed is one.
@awalker I get a ton of these messages as well…I’m using 8.0.14. They are marked as warnings so I would assume it’s not optimal to be seeing this?
I believe this will be resolved in the 8.0.16 version.
Actually the believed fix is out in the 8.0.16 nightly as of this morning.
I got the same error, plus a similar one as well - are they related?
If I use a binding (any binding, even just a line of text) on the Time Series Chart, I get this error:
“The “series” property is not configured correctly […]. ui.ErrorBoundary: Component error caught in error boundary: undefined”
I’ve used an expression to link to a dynamic path in the custom properties:
“aggregate”: “Average”,
“path”: “[default]Tag1/Tag1 values”, <-- fake path, to protect customer data
“alias”: “Tag1 Data”
If I try to bind the path, so that the path can be Tag1 or Tag2, I get the above error.
There is no error if I bind the alias, only the path (even if, as I said, I simply bind to a static string).
Is there some sort of race condition happening in the browser?
By the way, the chart displays absolutely perfectly in spite of the error.
Karen
EDIT - just seen it has been resolved in the latest release.
