I have some graphs that were functioning correctly before the upgrade using the Chart component. Now when I run them, the graph is not displaying and I get the following error
com.inductiveautomation.factorypmi.common.xmlserialization.SerializationException: Error invoking [PMIChart]com.inductiveautomation.factorypmi.application.components.PMIChart[chFiller,0,112,405x281,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=java.awt.Dimension[width=405,height=281]].setDynamicProps({Cumulative=Cumulative, Data=Data})
	at com.inductiveautomation.factorypmi.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:82)
	at com.inductiveautomation.factorypmi.common.xmlserialization.deserialization.handlers.ComponentDeserializationHandler.endSubElement(ComponentDeserializationHandler.java:83)
	at com.inductiveautomation.factorypmi.common.xmlserialization.deserialization.XMLDeserializer$Parser.endElement(XMLDeserializer.java:368)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
	at com.inductiveautomation.factorypmi.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:142)
	at com.inductiveautomation.factorypmi.application.model.WindowController.deserializeWindow(WindowController.java:619)
	at com.inductiveautomation.factorypmi.application.model.WindowController._loadWindow(WindowController.java:324)
	at com.inductiveautomation.factorypmi.application.model.WindowController.getWindow(WindowController.java:368)
	at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:836)
	at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:817)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$7.run(NavUtilities.java:366)
	at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:463)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:364)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java)
	at org.python.core.PyObject.__call__(PyObject.java)
	at org.python.core.PyObject.invoke(PyObject.java)
	at org.python.pycode._pyx6.f$0(<event:actionPerformed>:6)
	at org.python.pycode._pyx6.call_function(<event:actionPerformed>)
	at org.python.core.PyTableCode.call(PyTableCode.java)
	at org.python.core.PyCode.call(PyCode.java)
	at org.python.core.Py.runCode(Py.java)
	at com.inductiveautomation.factorypmi.application.script.ScriptManager.runCode(ScriptManager.java:245)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:145)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:287)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at $Proxy0.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.awt.Component.processMouseEvent(Unknown Source)
	at javax.swing.JComponent.processMouseEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
	at java.awt.Window.dispatchEventImpl(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
	at com.inductiveautomation.factorypmi.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:69)
	... 65 more
Caused by: java.lang.IllegalArgumentException: Range(double, double): require lower (Infinity) <= upper (-Infinity).
	at org.jfree.data.Range.<init>(Range.java:90)
	at com.inductiveautomation.factorypmi.application.components.chart.runtime.CategoryDataSet.calcRange(CategoryDataSet.java:91)
	at com.inductiveautomation.factorypmi.application.components.chart.runtime.CategoryDataSet.setDataSet(CategoryDataSet.java:69)
	at com.inductiveautomation.factorypmi.application.components.chart.runtime.CategoryDataSet.<init>(CategoryDataSet.java:45)
	at com.inductiveautomation.factorypmi.application.components.PMIChart.createCategoryChart(PMIChart.java:535)
	at com.inductiveautomation.factorypmi.application.components.PMIChart.createChartImpl(PMIChart.java:477)
	at com.inductiveautomation.factorypmi.application.components.chart.PMILineChartPanel.createChart(PMILineChartPanel.java:115)
	at com.inductiveautomation.factorypmi.application.components.PMIChart.setDynamicProps(PMIChart.java:1313)
	... 70 moreI also clicked on the send to Inductive button on the error message.
