This is not a big deal and I am not sure where this should be posted but I found an error in the manual. I discovered this because I often copy the example code from the manual so I get the syntax correct (I have a bad memory).
In the section system.file.openFile the example code is: [code]path = system.db.openFile(‘gif’)
if path != None:
do something with the file[/code]
and it should be…
[code]path = system.file.openFile(‘gif’)
if path != None:
I’ve verified that it’s still there, and I’ll fix it. Won’t make it into 7.6.5-rc2, but should be in rc3. I don’t know how quickly the website picks up fixes, but it will make it there eventually.
[edit]
Fix is done for both 7.6.5 and 7.5.12. Thanks for the heads up.
