Error in perspective popup `onStartup` script when opening screen in designer, object does not support item assignment
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 13, in runAction TypeError: 'instancemethod' object does not support item assignment
at org.python.core.Py.TypeError(Py.java:234)
at org.python.core.PyObject.setitem(PyObject.java:731)
at org.python.pycode._pyx193.runAction$1(:17)
at org.python.pycode._pyx193.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.call(PyFunction.java:469)
at org.python.core.PyFunction.call(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:868)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1010)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:950)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:161)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:98)
at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:80)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.lambda$call$0(ActionCollection.java:263)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.mdc(LoggingContext.java:54)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:252)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:221)
at com.inductiveautomation.perspective.gateway.threading.BlockingTaskQueue$TaskWrapper.run(BlockingTaskQueue.java:154)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException: TypeError: 'instancemethod' object does not support item assignment
... 28 common frames omitted
Hello and welcome aboard,
Here are a few tips to make your stay with us pleasant for everyone:
  • when posting code, stack traces, error messages... use the built-in code formatting tool, it makes things much more readable by using a monospaced font and preserving indentation
  • make the title descriptive, but keep it short. You can add details in the body of the post.
  • when asking for help fixing an error, show the code/what you're doing. We can't help you find what's wrong without access to what have.
  • we are NOT support, only users willing to share what we know. Keep that in mind when posting.
  • even if we were support, we'd still be human people (I think ?) and it's usually a good idea to observe at least some basic level of politeness when addressing human people. Especially when asking for help.
Here, the error tells us that on line 13 of a script assigned to the onStartup event of your view, you're trying to assign a value to something that's read-only or not built to receive values.
For more details, we'll need to see the code.
And remember: when posting code, use the formatting tool. Post the actual code, not a screenshot.
