Hello everyone! I have a question regarding an error that appears in the binding of the historical tag type. Let me explain a little bit the error:
I have an embedded view that has data in its custom properties that pass directly to a graph within it, what happens is that when I configure the historico to as shown in the image (It is worth mentioning that it has a mapping that can be seen in the preview) when I put that the parameter: end date has the command now(1000) to run every second, in the binding preview it marks me only 3 points and does not return any value.
However, when I put to the parameter end date the same command but with the value of zero as shown in the following image, it shows me the values.
However, as far as I understand if the now command has the value of zero, it will not be updating every second and that I will is that the value updating every second, my question is: Has anyone had something similar happen and how solved it? or How could I fix it?
I hope that anyone can help me!
