Error installing Ignition 8.1 on Suse SLES 15SP4 libglassgtk3
Loading library glassgtk3 from resource failed: java. lang. UnsatisfiedLinkError: /root/.openjfx/cache/17.0.2-ea/libglassgtk3.so: libgthread-2.0.so.0: cannot open shared object file: No such file or directory
gtk libs are installed:
SRVIGNITION01:~ # zypper search -i gtk
Loading repository data...
Reading installed packages...
S | Name | Summary | Type
i | gtk2-branding-SLE | The GTK+ toolkit library (version 2) -- SLE theme configuration | package
i | gtk2-lang | Translations for package gtk2 | package
i | gtk2-metatheme-adwaita | Adwaita GNOME Theme -- GTK+ 2 Support | package
i | gtk2-theming-engine-adwaita | Adwaita GTK+ Theming Engine | package
i | gtk2-tools | Auxiliary utilities for the GTK+ toolkit library v2 | package
i | gtk3-branding-SLE | The GTK+ toolkit library (version 3) -- SLE theme configuration | package
i | gtk3-data | Data files for the GTK+ toolkit library v3 | package
i | gtk3-lang | Translations for package gtk3 | package
i | gtk3-metatheme-adwaita | Adwaita GNOME Theme -- GTK+ 3 Support | package
i | gtk3-schema | Config schema for the GTK+ toolkit library v3 | package
i | gtk3-tools | Auxiliary utilities for the GTK+ toolkit library v3 | package
i | gtk4-branding-SLE | The GTK+ toolkit library (version 3) -- SLE theme configuration | package
i | gtk4-schema | Config schema for the GTK+ toolkit library v4 | package
i | libgtk-2_0-0 | The GTK+ toolkit library (version 2) | package
i | libgtk-3-0 | The GTK+ toolkit library (version 3) | package
i+ | libgtk-4-1 | The GTK+ toolkit library (version 4) | package
i+ | libgtk-vnc-2_0-0 | A GTK widget for VNC clients | package
i+ | libgtksourceview-3_0-1 | GTK+ Source Editing Widget | package
i+ | libgtksourceview-4-0 | GTK+ Source Editing Widget | package
It's actually looking for libgthread-2.0.so, though I'm not familiar with SUSE and don't know what you need to run to figure out what package provides it.
Solved with
zypper install libgthread*
Thank you
