Error : java.lang.Exception: Unable to get the view config: View config is undefined
I have a projects with multiple views. Each time I try to open any view I get the error message below:
Any thoughts!
Appreciate everybody help.
Error Message: java.lang.Exception: Unable to get the view config: View config is undefined.
The full error details are below:
java.util.concurrent.ExecutionException: java.lang.Exception: Unable to get the view config: View config is undefined.
at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:491)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:68)
at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.commit(ResourceEditor.java:166)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.notifyDeactivated(ViewResourceEditor.java:598)
at com.inductiveautomation.perspective.designer.workspace.PerspectiveWorkspaceListener.editorSelected(PerspectiveWorkspaceListener.java:80)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace$3.stateChanged(TabbedResourceWorkspace.java:116)
at java.desktop/javax.swing.DefaultSingleSelectionModel.fireStateChanged(Unknown Source)
at com.jidesoft.swing.JideTabbedPane$IgnoreableSingleSelectionModel.fireStateChanged(Unknown Source)
at java.desktop/javax.swing.DefaultSingleSelectionModel.setSelectedIndex(Unknown Source)
at java.desktop/javax.swing.JTabbedPane.setSelectedIndexImpl(Unknown Source)
at java.desktop/javax.swing.JTabbedPane.setSelectedIndex(Unknown Source)
at com.jidesoft.swing.JideTabbedPane.setSelectedIndex(Unknown Source)
at java.desktop/javax.swing.JTabbedPane.setSelectedComponent(Unknown Source)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.open(TabbedResourceWorkspace.java:254)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.open(TabbedResourceWorkspace.java:244)
at com.inductiveautomation.perspective.designer.workspace.nav.ViewNode$DelayedOnSelect.run(ViewNode.java:535)
at com.inductiveautomation.ignition.client.util.EDTUtil$ProcessQueue.run(EDTUtil.java:126)
Caused by: java.lang.Exception: Unable to get the view config: View config is undefined.
at com.inductiveautomation.perspective.designer.workspace.JavaJsBridge.onSaveError(JavaJsBridge.java:124)
at com.teamdev.jxbrowser.frame.internal.FrameImpl.invokeMethod(FrameImpl.java:785)
at com.teamdev.jxbrowser.frame.internal.FrameImpl.processCallback(FrameImpl.java:228)
at com.teamdev.jxbrowser.internal.rpc.stream.CallbackStream.process(CallbackStream.java:178)
at com.teamdev.jxbrowser.internal.rpc.stream.Stream$StreamObserver.lambda$onNext$0(Stream.java:164)
at com.teamdev.jxbrowser.internal.BrowserThread$TaskRunner.processTasks(BrowserThread.java:139)
Ignition v8.1.26 (b2023032308)
Java: Azul Systems, Inc. 11.0.18
how do you plan to implement navigation in the project?
  • I think you need to click on "Views" in the project browser
  • then the plus sign beside Page Configuration
I am getting the same error. This view has been in place over a year working perfectly. Did you find a resolution?
Press the Shift key on the keyboard, right-click on the View, and choose "Refresh Browser."
I think this is a solution!
