My client started receiving these messages. Currently on 8.0.10
Client is a Windows 10, 64 bit.
Hmm… it looks like maybe the keystore is empty/corrupt/unable to be read for some reason?
Try to delete project shortcut and remove it from Vision Client Launcher…And add it again and retry lauching.
Question?
Does this happen if you launch it from the designer (F10)?
Removing and adding again didn’t fix it.
Launching from the designer has the same issue.
Deleting the .ignition folder in the client fixed it.
I was about the tell to read the logs and finally browse to .ignition logs
Nice, But I’m not sure about the implications of deleting the whole folder
After deleting… the folder created again?
