i am new user to ignition. while launching designer application. following Error generated.
IO execption: Unable to delete the file.
C:\user\arun k\ignition\cache\resources\runtime\11.0.13\bin\java.exe
if try deleting the file manually fault generates as it is being used by zulu platform.
kindly help
If you close any Vision Client or Designer instances you have open can you delete the file?
nope . i was unable to do. but i cleared the error by ending zulu architecture 64 X in task manager. after that it is working . thanks anyways
I am getting the same error
