Just created a desktop icon for one of my Ignition project and when i launch it i get this error.
Any help ?
Any help ?
How did you create the desktop icon?
Can you share the execution path of the icon?
What version of Java are you using to launch? It looks like youâre using too late of a version for 7.9, which doesnât support anything past Java 9.
Iâm using Java 8
I would like to create a shortcut for a project, but despite checking the box in the client launcher, the shortcut is not created.
Looks like youâre using Ubuntu.
Attached is a desktop file that should have the basics of what you need. Youâll need to edit it to the appropriate paths, but it should work with your client launcher.
MyProject.desktop.zip (363 Bytes)
Make sure its set to be executable, then right-click on the file and select âAllow Launchingâ
A pretty fair tutorial is here. Youâd be at Step 3. How to Add Desktop Shortcut on Ubuntu Linux.
Sorry, just realized youâre on v9. The command line is bit different , IIRC.
https://docs.inductiveautomation.com/display/DOC79/Native+Client+Launchers
Thanks a lot ! Working with this path: ./clientlauncher.sh scope=C project=myterminal windowmode=fullscreen screen=0 show.closebutton=false
