Error listing tables for database connectio
Hello everyone, I just did a default BD update in the overall project, and when I want to make a query I get the error that does not find any BDs, but in the designer if the queries work but published no longer.
Excuse my English and thank you for your help.
Captura
I was able to fix this, I just changed the default database to the correct one, but now the problem I have is that I can see data from the designer but when i move to a client I mark the following marks the following:
In the designer:
Someone will know why this happens??
That’s probably due to missing legacy database access security permission. Look in your project properties to set that. You need it for database pens on the EasyChart.
thank you very much, if it was project permits.
