We have a project that won’t load in the designer. We keep getting this error when loading.
The text is.TypeError: ‘com.inductiveautomation.ignition.common.script.ScriptModule’ object does not support item assignment
at org.python.core.Py.TypeError(Py.java:235)
at org.python.core.PyObject.__setitem__(PyObject.java:667)
at org.python.core.PyObject.__setitem__(PyObject.java:686)
at com.inductiveautomation.ignition.common.script.ScriptManager.addScriptModule(ScriptManager.java:217)
at com.inductiveautomation.ignition.common.script.ModuleLibrary.installScriptsUnderPackage(ModuleLibrary.java:89)
at com.inductiveautomation.ignition.common.script.ModuleLibrary.install(ModuleLibrary.java:62)
at com.inductiveautomation.ignition.common.script.ModuleLibrary.install(ModuleLibrary.java:54)
at com.inductiveautomation.ignition.designer.DesignerContextImpl.<init>(DesignerContextImpl.java:190)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:830)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:800)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$35.openProject(IgnitionDesigner.java:3086)
at com.inductiveautomation.ignition.designer.ProjectDialog$3.run(ProjectDialog.java:182)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
Ignition v7.9.12 (b2019070213)
Java: Azul Systems, Inc. 9.0.7.4
