Ok I have the following query:
SELECT machine,start,shift,a.ProdEmpFirstName + ' ' + a.ProdEmpLastName as mech1,mech2,verb1 as status FROM DJT_MECH_REPORT as i
left outer join ProdEmployee AS a ON a.ProdEmployeeID = i.mech1 where datediff(day,prod_date,'{Root Container.Container.mechresp.Calendar.formattedDate}')=0
order by machine,start
Problem is if I run it, I get the QUERY MUST RETURN A RESULTS SET error message. Here is the dialog for that.
[java.sql.SQLException: The executeQuery method must return a result set.
at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQLQuery(JtdsStatement.java:429)
at net.sourceforge.jtds.jdbc.JtdsStatement.executeQuery(JtdsStatement.java:1258)
at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at com.inductiveautomation.factorypmi.gateway.servlets.Gateway$2.run(Gateway.java:1867)
at com.inductiveautomation.factorypmi.gateway.servlets.Gateway.doDBAction(Gateway.java:2291)
at com.inductiveautomation.factorypmi.gateway.servlets.Gateway.runQuery(Gateway.java:1852)
at com.inductiveautomation.factorypmi.gateway.servlets.Gateway.doPost(Gateway.java:332)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at com.inductiveautomation.factorypmi.gateway.ErrorReportValve.invoke(ErrorReportValve.java:95)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Unknown Source)
Now what is really odd is if i change the WHERE CLAUSE to look like:
where shift =1 and datepart(day,prod_date,'.....')
I do not get the error message and the query returns the correct information. So what I am missing? Does datepart need other where clause information to work properly?
