Here is an error message I am receiving from my startup script. The thing is this does not occur every time. If I start the project in runtime say 10 times at least 3 will have this error message where the other 7 will be fine.
[quote]Traceback (innermost last):
File “”, line 25, in ?
java.lang.ClassCastException: Error trying to coerce ‘Fair’ to a class java.lang.Integer
at com.inductiveautomation.factorypmi.common.utils.TypeUtilities.coerce(TypeUtilities.java:511)
at com.inductiveautomation.factorypmi.application.sqltags.db.TagFacade.setAttribute(TagFacade.java:117)
at com.inductiveautomation.factorypmi.application.script.builtin.TagUtilities.writeToTag(TagUtilities.java:80)
at com.inductiveautomation.factorypmi.application.script.builtin.TagUtilities.writeToTag(TagUtilities.java:59)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java)
at org.python.core.PyObject.__call__(PyObject.java)
at org.python.core.PyObject.invoke(PyObject.java)
at org.python.pycode._pyx0.f$0(<startup script>:25)
at org.python.pycode._pyx0.call_function(<startup script>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.factorypmi.application.script.ScriptManager.runCode(ScriptManager.java:245)
at com.inductiveautomation.factorypmi.application.script.ScriptManager.runCode(ScriptManager.java:238)
at com.inductiveautomation.factorypmi.application.FPMIApp.startup(FPMIApp.java:672)
at com.inductiveautomation.factorypmi.application.runtime.RuntimePanel.initFPMIApp(RuntimePanel.java:626)
at com.inductiveautomation.factorypmi.application.runtime.RuntimePanel$LoginAction.doLogin(RuntimePanel.java:996)
at com.inductiveautomation.factorypmi.application.runtime.RuntimePanel$LoginAction.tryLoadApp(RuntimePanel.java:1041)
at com.inductiveautomation.factorypmi.application.runtime.RuntimePanel$LoginAction.access$300(RuntimePanel.java:942)
at com.inductiveautomation.factorypmi.application.runtime.RuntimePanel$LoginAction$LoginLockWaiter$1.run(RuntimePanel.java:963)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
java.lang.ClassCastException: java.lang.ClassCastException: Error trying to coerce ‘Fair’ to a class java.lang.Integer
at org.python.core.Py.JavaError(Py.java)
[/quote]
Here is the code that is being ran that causes this error message.
val = fpmi.net.getIpAddress()
if val[0:2]=='10':
fpmi.gui.openWindow("Window 1")
else:
import fpmi
import re
fpmi.gui.openWindow("Window 1L")
response = fpmi.net.httpGet("http://xml.weather.yahoo.com/forecastrss?p=17815")
# import Python's regular expression library
# import re
# NOTE - if you've never seen regular expressions before, don't worry, they look
# confusing even to people who use them frequently.
pattern = re.compile('.*?<yweather:condition (.*?)/>', re.DOTALL)
match = pattern.match(response)
if match:
subText = match.group(1)
condition = re.compile('.*?text="(.*?)"').match(subText).group(1)
temp = re.compile('.*?temp="(.*?)"').match(subText).group(1)
fpmi.tag.writeToTag("[]temp",toint(temp))
fpmi.tag.writeToTag("[]condition",str(condition))
else:
print 'Weather service format changed'
I have triedit with both toint and str. When I tried it with str the tag that I wrote to was a string, when I try it with the toint the tag is set as an int. So I dont think there is an issue but since I am getting the error message there must be something.
