Hello everyone
I need connect a new database connection whit SQL sever locally , I setting the conection but I recibet the next error
I configurate the TCP/IP properties
this is my conection
What version of SQL Server are you using?
Double-check that you have all the configuration correct.
https://www.sqlshack.com/sql-server-network-configuration/
"Connection refused"
That is a pure networking error, typically caused by nothing listening on the target port, but sometimes also caused by firewall rules. Double check your IP addresses, listening ports, and firewalls.
Hi, Antonio, I usully enable the TCP/IP protocol. like in this image.
And make sure to open 1433 port in your firewall.
Can you connect to the database using other client? like sql server management studio?
I have used the SQL server 2022,This is a local connection, yes I can connect used the user sa on management studio
Have you tried the settings show in the documentation?
Connecting to Microsoft SQL Server - Ignition User Manual 8.1 - Ignition DocumentationMSSQL Settings
