Error on project save
Using Ignition 8.1.5 I’m getting unusual behavior when trying to save a project.
The behavior is basically this:
  1. I push the ‘Save All’ icon in the designer.
  2. The designer freezes for ~30seconds
  3. The standard Error Dialog Box pops up showing 4 errors but no text and no details.
  4. The console contains this.
After the error is thrown I seem to able in interact with the designer as normal, but if I try to save I start back over at step 1.
I closed the designer (without saving for obvious reasons) and reopened the same project. The changes I was trying to save were present, so apparently the save operation was successful. After reopening, the designer behaved as expected.
There maybe isn’t anything to fix, but I’ll leave this description here in case others experience similar issues.
08:35:37.865 [AWT-EventQueue-0] WARN Perspective.SessionProps - Unable to obtain session props for save.
java.util.concurrent.TimeoutException: null
	at java.base/java.util.concurrent.CompletableFuture.timedGet(Unknown Source)
	at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter.commit(SessionPropsAdapter.java:222)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.WorkspaceRootConfig.commit(WorkspaceRootConfig.java:22)
	at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.notifyProjectSaveStart(ViewWorkspace.java:304)
	at com.inductiveautomation.perspective.designer.DesignerHook.notifyProjectSaveStart(DesignerHook.java:400)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.commitAll(IgnitionDesigner.java:1580)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.handleSave(IgnitionDesigner.java:1346)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handleSaveAction(IgnitionDesigner.java:2759)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$5.actionPerformed(IgnitionDesigner.java:2347)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
	at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:99)
08:35:47.916 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - null
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:434)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:63)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.commit(ResourceEditor.java:160)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.commitAll(TabbedResourceWorkspace.java:331)
	at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.notifyProjectSaveStart(ViewWorkspace.java:306)
08:35:57.932 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - null
08:36:07.953 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - null
08:36:17.959 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - null
08:36:18.146 [AWT-EventQueue-0] INFO designer.update-and-save - Save finished in 112ms.
You should update as soon as possible.
The gist of this error is that we tried to ask the Perspective session running "inside" the designer for your session prop configuration + a particular view's configuration. We "ask" for that, then wait 30 seconds, and if we don't get a response, give up.
If that happens and you save, you could potentially overwrite valid configuration with nothing, effectively deleting resources.
In later versions, we've fixed various bugs on the frontend that cause instabilities, and upgraded JxBrowser. We're also in the middle of updating the browser library again to the absolute latest, which should hopefully help with this issue more.
